Pattern on curve in assembly
Hey guys,
for my uni project im building an autonomous tank robot that needs to negotiate a maze.
Anyway im having trouble puitting together the tank track arrangement in Assembly mode. My teacher thinks you can use the pattern along curve function but he isnt 100% certain.
Ive drawn the sketch and imported the part into the mode, i just cannot get it to work, not even get the pattern along curve button to become active!
Any help will be greatly appreciated.
Thanks!
-Gribble-
Thanks!
-Gribble-
RE: Pattern on curve in assembly
'pattern along curve' is active only when you've created an
assembly feature i.e. a hole/cutout created within the
assembly. You may sketch your curve as an assembly sketch(!)
put a hole/protrusion at one end and then you'll be able
to use that feature.
Or you create the pattern along curve within the part itself
for example a hole pattern. This pattern can be used in an
assembly as usual
dy
Thanks for your help.
