Looking for pressure and flow indicators
This may not be the right forum, if so I apologize and request appropriate redirection.  I'm looking for low air pressure (on the order of 0.02 pounds per square foot) and low air flow (on the order of 10 to 100 CFM) instruments.  This is for a "proof of principle" type of exercise.  Thanks in advance!!
RE: Looking for pressure and flow indicators
You might look into anemometers for flow and manometers for pressure.
Ted
Dwyer is a manufacturer that sells low pressure gauges such as the Magnehelic. Thermo Brandt manufactures flow measurement products for ducts and pipes.
