Flange dwg Drawings
Flange dwg Drawings
Flange dwg Drawings
Hey,
Just trying not to re-invent the wheel here. Can anyone point me in the direction of stanard Flange Drawings and butterfly valve drawings in dwg. Would save me many hours trying to reproducethese myself.
Many Thanks,
RE: Flange dwg Drawings
A Google search will turn up plenty.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Apr 30, 2008)
Been there done that, many times before posting this question.
All I managed to get (after sifting through numerous sites) was drawings, not the "dwg" files.
Perhaps your google search is better than mine. How about linking a couple of suitable sites?
Try,
http://www.mcmaster.com/
When you select a flange, you can select a 2D drawing or a 3D model in various formats, don't know about valves.
Thanks Metalfixer, exactly what I was looking for.
iken  ...Just curious, WHY would you need detailed drawings of both flanges and butterfly valves? ...Did you know all butterfly valves don't look the same?
11echo,
Yeah I know all butterfly valves are not identical (from manufacture to manufacture). I am after these for Pipe layout drawings within plant rooms (Chilled & Heating water). The valves is more an asthetic view, than dimesional correct (the only dimension that will have any effect is the thickness anyway).
Cheers
