Low Temperature Carbon Steel
ASME VIII Div.1 is used for the vessel design. If the MDMT is colder than -29 DegC and warmer than -46 DegC, Low Temperature Carbon Steel is selected, for example, SA516-70N.
My questions:
(1) Is impact test required when MDMT colder than -29 DegC? Or dependS on UCS-66? (In ASME VIII Div.1, if the thickness and temperature combination located above UCS-66 curve D, impact test can be exempted.)
(2) If impact test required, which one is impact tested (Base metal, HAZ, weld, or all)?
(3) If impact test exempted at a temperature lower than -29C, which one is exempted (Base metal, HAZ, weld, or all)?
please advice, thanks.
My questions:
RE: Low Temperature Carbon Steel
