NX5 Part Families
NX5 Part Families
NX5 Part Families
Is there a way to make a member of a part family not associated to the template?
RE: NX5 Part Families
Save it off under a new name.
Believe it if you need it or leave it if you dare. - Robert Hunter
Jerry,
You'll probably need to test this, but I think that all you technically have to do it save it into another directory. You could call it the same name, so that depending on how you're loading parts you may well have something to gain in terms of maintaining your existing assemblies.
Best Regards
Hudson
Use File->Save-As to a new filename.
Now if you want to simply unassociate it from the template, with the template and the member open, go into the spreadsheet, delete that particular record and save the spreadsheet and the template. It will give you a message that the member is being deleted from the template.
Specialty Engineered Automation (SEA)
http://www.sea4ug.com
a UGS Foundation Partner
Thank you very much for all the tips. When I get to work on Monday I will try them.
