Pinhole in HDPE pipe
I need some information regarding pinhole in HDPE gas pipe. I heard there is some information available in PPI.
Would anyone please let me know where I can find some pinhole information except ionixtechnologies info?
Parvez
RE: Pinhole in HDPE pipe
I suspect you may be referring to the paper, "Static control in PE Fuel Gas Pipe", that I think has been published in many forms over several years (with maybe latest at http://www.ionixgastechnologies.com/Static%20Control%20in%20PE%20Fuel%20Gas%20Pipe.pdf).  In any case I suspect GTI (formerly GRI etc.), as a result of their research/data gathering etc., likely knows something about this subject (if you have access to this resource/information).
Thanks Conner.
Rgds
parvez
(oops, I should have also mentioned "AGA")
