External Surface Area Of Vessel
Hi All
Is there any any to find out the total external surface area in Compress Calcs Report? Thanks
RE: External Surface Area Of Vessel
Sorry for the typo. I'd like to know if compress calculates the external surface area of the vessel including nozzle surface area. Thanks
COMPRESS does not calculate or report the surface area. I've floated this idea in the past. Maybe someday it will be done.
"Although this forum is monitored by Codeware it is not intended as a venue for technical support and should not be used as the primary means of technical support."
  Tom Barsh
  Codeware Technical Support
For C.S. equipment, it can be used for calculating the painting.
