Locking Options in Excel
Is there a way to prevent other users from changing the options in Excel?  Example is to prevent a change to "Move after Enter" under the Edit tab.
RE: Locking Options in Excel
Possibly the "safemode switch" in the command line...
excel.exe /s
Run Excel in this manner and see if this will work for you.
It may limit too much.
You can with vba inserted in the workbook open module.
Record a macro and set or unset the settings you want to stick to get the code.
-Mark
