col'n modification
col'n modification
col'n modification
We consider to change the atm col'n to the vaccume col'n.
(operation condition)
If you change it, the problem and check points are inform to us. thanks..
RE: col'n modification
You'll have to look at the whole column mechanical design.  Tanks under vacuum have a whole new set of calculations for fabrication.
