heavy duty Pipe bracket /swing arm
I am looking for a prefab part that would take a 2 inch pipe and allow the pipe to swing possibly with a nylon bushing. This bracket would be attached to a vertical surface and allow the pipe to swing up and down.
Does anyone know of such part.
Use: Attach an awning pole to a deck. The pole would support cables of which an awning would be attached. The awning will need to handle medium to moderate wind so the pipe will have to be thick wall and the bracket should be welded steel or heavy cast aluminum.
RE: heavy duty Pipe bracket /swing arm
McMaster Carr (www.mcmaster.com)
p/n  4936T99 galv. steel,  4698T221 alum.
or did you mean like these:  4936T121 (galv)
btrueblodd, Thank you for the quick response.
4936T121 looks to be what I am looking for in function but it may be too light weight.
I was thinking something like a T-bar inside a channel type housing or bracket I know there are some heavy duty applications that would use this but can not find a thing out there.
