Unable to edit line properites
When I click a entity, properties on ribbon bar display gray (non-editable) How I can turn it to editable?
This happens in both sketch & draft environment.
RE: Unable to edit line properites
Good luck.
in case the option: Inspect --> Sketch Relationship Colors
is active you can't edit the line properties. This may
also propagate through to a draft (rare)
dy
