jpg to dxf in solid edge
I'm new to cad and have a specific problem to figure out. I imported a jpg picture into solid edge, traced whatever I needed as a sketch, and now need help figuring out what else I need to do so I can save the file (or export it) as a dxf file. Can anyone give me a few tips. Thanks.
Logan
Logan
RE: jpg to dxf in solid edge
File > Save As
then in the filetype box select dxf.
You might need to check/change export settings with the Options button.
bc.
CAD2 Imagine Workstation
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
dxf files are not listed in my "save as", so are you talking about the options button under "tools"? I could not find any way to change my export settings in that menu.
Should I have created this part from a solid part, sheet metal or does it matter? This is a simple 2d logo for someone to burn with a laser.
Thanks again.
From draft environment, save as like Beach says.
KENAT, probably the least qualified checker you'll ever meet...
