Adding animated flow lines to a composed DXF
I am trying to animate flow lines in a Hydraulic schematic made in AutoCad, as an overlay showing direction of flow. Can you offer suggestions on how to do it.
Thank you
Thank you
RE: Adding animated flow lines to a composed DXF
http://virtualpipeline.spaces.msn.com
"What gets us into trouble is not what we don't know, its what we know for sure" - Mark Twain
Thank you I have tried both suggestions, I was able to move the schematic to Excel, but there are no features there for the process "animation", Keeping it simple a stream or flow of fluid colored red & white movement in line from a pump to a valve etc. Having said that I have not lost hope. I know there is a way.
