Leader Lines on Faceted Representation Views
I have a base view created using a facted representation.
I wish to add a note with a leader line to point to a specific part in the view.
The leader command selects the facet ok where i selected it, it then generates the leader line miles away from where i selected it.
any ideas?
cheers
RE: Leader Lines on Faceted Representation Views
Version? I forget which one people are on though I know you've posted here before.
Try other locations nearer the edge. I have managed to get parts list ID balloons to work okay for such views. I haven't tested for other types of notes.
Are you loading facet reference sets or solids. Given enough info I'm happy to perform some kind of test to verify your problem, it's how I learn wink.
Best Regards
Hudson
