D1.3 & Macrophotograph Requirement
We are using a GMAW procedure to seal weld a container's sheet metal wall. We had to submit our procedure for review.
We've been asked to submit a copy of the macrophotograph of the weld used in qualifying the procedure. Unfortunately, we did not get it done as we were only using the procedure to weld a few seams of sheet metal.
I've been told that they will grant a deviation if I submit a request. However, I need to know under what conditions does AWS D1.3 require a macrophotograph to be supplied?
Any comments would be much appreciated.
RE: D1.3 & Macrophotograph Requirement
the Hire yourself a Full time CWI to help with these questions
sorry I did not have more time to chase this down but if I doo find something I will let you know
