SW2008 drawing problems
Just got a new computer with SW2008 already installed on it. Most everything is working ok but there are two problems I can't figure out how to fix:
1. New drawings default to 1st angle projection and have to be changed manually to 3rd angle each time, even when adding a new sheet. I think some kind of config program has to be re-run but I don't know where to find it.
2. Annotations added to a view, like notes, finish marks, geometric callouts, don't move with the view if it is dragged. I could not find a setting in properties to fix this.
By the way, I am at SP0.0, so that might be the problem. I have just been reluctant to upgrade yet for fear of introducing new problems.
Thanks for your help.
RE: SW2008 drawing problems
2. I haven't heard of anyone else having this issue and can't replicate it. I would, however, recommend updating to 3.1.
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo, 4GB RAM, Nvidia 3500M
-handleman, CSWP (The new, easy test)
If that doesn't solve problem #2;
a) Try resetting the registry ... FAQ559-507: Alternative to try before reinstalling
b) RMB on a view and select Lock View Focus before placing notes, etc.
c) Do a clean reinstall of SW (with anti-virus disabled) ... FAQ559-488: How do I do a clean uninstall & reinstall of Solidworks?
CSWP
SolidWorks 2007 SP5.0/2008 SP0.0
2xDual-Core AMD OPTERON 280 / 8GB Ram
Quadro FX3450
3DConnexion SpaceNavigator
You can right-click on the view and select Lock View Focus and then any note you create will be associated with that view until you unlock the focus.
Give that a try.
- - -Updraft
my notes (and even hole callouts) are attached to the view, not the sheet. When I move the view, the attached notes will ocasionally lag behind. But as I stated in my last post a "ctrl-q" will speed up the lag, and place them back to where they are supposed to go.
CSWP
SolidWorks 2007 SP5.0/2008 SP3.1
Quadro FX3450
