Temperature Profile in Pipe due to Soil
What (or where) are the equations for heat transfer between fluid-pipe-soil?
I have a pipeline simulator and am determining the temperature decline of a gas.  The pipeline is buried 3' under the soil line and the soil line is 100' under water.  As I run the model with decreasing flow rate, I found the temperature drops slowly until about a 40% drop in flow rate.  Then the temperature drops a little more rapidly.  What determines this threshold?
I also assumed no significant outer wrap...
