Need a transformer(s) to go from 21.6 kV to 34.5 kV.
We are looking for a transformer(s) to go from 21.6 kV to 34.5 kV. Since this is not a common transformer, we are looking at using two transformers back-to-back, a 21.6 kV / 480 V. with a 480 V / 34.5 kV and each approximately 2500 kVA. Any suggestions on where we could locate a 21.6 kV transformer as this does not appear to be a common voltage outside of Texas.
RE: Need a transformer(s) to go from 21.6 kV to 34.5 kV.
You want a ratio of around 1.6:1 (i.e., 34.5/21.6). I'd look for a transformer with higher voltages than you need but with a 1.6 ratio. It's possible you might find a standard rating this way, but I'm not sure.
Also, if you find something close, you can get fixed taps to adjust the ratio further.
You can but I think only if the low side's insulation is rated for the high sides voltage. An open of the common winding gets you the Full Monty downstream.
Keith Cress
Agree with Magoo2 and you Zazmat. Used two trafos back to back.
Regards.
Slava
I'd try Cooper, ABB, GE-Prolec, Howard, etc. and see what they say.
Liquid filled, dry, or cast coil?
I would have to check on that, but do you know of any type that is available?
Zeeshan
I think they would be happy to build you an autotransformer for the right price.
You might also look for a 20.8 kV transformer, which is a semi-standard voltage in the northwest US. The taps could probably get you to where you need to go.
This will probally be a custom job if you dont want to use 2 units. If you want to use 2 I can provide those also but as mentioned above, not the best idea.
Consiter your application for ground source. An auto transformer is a good option.
Interesting enough the phase to ground voltage for 34.5kv is about 20kv, or close to the Phase to phase voltage you are looking for.
As for being common, it take days to replace a commonly available one as well so if you are worried about that it needs to be addressed by redundancy in the design. I also agree that using two transformers in series is inefficent and wastes space as well.
I'm so sorry.
I read now again thread. My bad!!!! I meant: not used two trafo back to back.
Sorry again.
Regards.
Slava
Do you have any contact info. I could forward to my folks?
