Expired Code Case 1298.5
Greetings
I'm looking at a vessel which was designed to the 1965 ASME Code and references that the nozzle neck material is per cc 1298.5 I could not find this referenced on the ASME.org site and am assuming that it has been withdrawn. If anyone has info on what this material is, and properties such as min specified ultimate tensile and yield strength with temp, would really appreciate it....
