Standardized CAD detail catalog
We have created a new system here at www.easy-d.com, and we are trying to get as much feedback and ideas from experienced architects and designers as possible. Our value proposition is simple, we save the architect and designer time in creating quality detail and spec sheets that are construction plan quality.
We have created a system that allows the architect and designer to download standardized .dwg editable CAD drawings and .pdf cut sheets for free. These drawings are all consistent, with the same line weights, fonts, and text. These details integrate seamlessly on a drawing sheet.
What we are asking for is as much feedback as possible. Our goal is to support the architect and designer by helping them produce drawings. Would this be a program that you would be interested in? Was the interface user friendly?
Check it out. Again, the system is free, and will always be free. This is for you, the architect, and we want to make this a viable tool for your library. Let me know at smccormack@peakstar.com
Thanks, Skip McCormack
RE: Standardized CAD detail catalog
Thanks and good luck!
