Interference check - ignore value?
Hi all,
You may have noticed how the draft analysis tool functions. You can actually specify a angle value to check from. The tool would generate report that shows all the angles more than specified value as green and lesser as red.
Similarly, is it possible to regulate the interference check tool.
In my assembly I dont want to have any interference more than 0.1mm. Whereas SW will consider this as a interference.
Can I regulate this?
BMR
BMR
RE: Interference check - ignore value?
