Append text without changing existing text formatting
I need to be able to append text to an existing cell without changing the existing text colors.  My current code looks like this:
CODE
If ActiveCell.Value = Empty Then
  ActiveCell.Value = Item & Chr(10)
  'TEXT COLOR ROUTINE
  With ActiveCell.Characters(, Len(Item) + 1).Font
    .Color = RGB(r, g, b)
  End With
Else
  Temp2 = ActiveCell.Value
  ActiveCell.Value = ActiveCell.Value & Item & Chr(10)
  'TEXT COLOR ROUTINE
  With ActiveCell.Characters(Len(Temp2), Len(Item) +1).Font
  End With
End If
The problem arises when the existing text is formatted with multiple colors.  It seems only the first color is maintained when the cell contents are re-written.  Since I've used these text colors to visually differtiate separate entities, this causes a problem.
RE: Append text without changing existing text formatting
You will have to temporarily store the existing character colors, for example:
CODE
Dim Temp2Color() As Variant
  ActiveCell.Value = myItem & Chr(10)
  'TEXT COLOR ROUTINE
  ActiveCell.Characters(1, Len(myItem) + 1).Font.Color = RGB(r, g, b)
Else
  ReDim Temp2Color(Len(Temp2))
  For i = 1 To Len(Temp2)
    Temp2Color(i) = ActiveCell.Characters(i, 1).Font.Color
  Next i
  ActiveCell.Value = ActiveCell.Value & myItem & Chr(10)
  'TEXT COLOR ROUTINE
    ActiveCell.Characters(i, 1).Font.Color = Temp2Color(i)
  Next i
  ActiveCell.Characters(Len(Temp2), Len(myItem) + 1).Font.Color = RGB(r, g, b)
End If
By the way, Item is a reserved word and it's better not to use it in your own code. You can see that I changed it to myItem.
Cheers,
Joerd
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Great, that solution is implemented and working in my code.  It seems obvious now that I see it, which means to me that it is an excellent solution!
I also replaced the variable name of "Item" with something more specific per your suggestion.  Thanks!
