MATHCAD Crashes when trying to use SmartSketch
I am new to both Mathcad and smartsketch and am trying to create the calculation driven sketches that seem to be possible using smartsketch within mathcad. I have Mathcad V14 which doesn't seem to come with the smartsketch samples indicated in the 12 step guide found in the FAQ section of this site. However, I can simply insert a new smartsketch drawing from the insert > components menu and draw some shapes there. All is well at this point. The problem arises when I try to click on any of the drop-down menus at the top of the screen (tools, format, etc), which I think I need to do to associate the sketch with a variable. As soon as I click on the these menus, the program crashes. PTC says they do not provide support for the SmartSketch component so I am at a loss for where to go from here. Am I following the wrong procedure for creating a smartsketch sketch?
Any help would be greatly appreciated.
RE: MATHCAD Crashes when trying to use SmartSketch
TTFN
TTFN
I'll have to wait until I get home to check the Smartsketch part of it.
TTFN
I'll try my copy of SmartSketch 3.0 and see what happens.
TTFN
TTFN
Hope this helps!
