Solenoid Core Magnetism
I have a situation with a customer. We make solenoid cores for them out of SD 200G, which is a 12L14 equivalent, with an electroless nickel plating. Cores made from one heat of material seem to perform fine. Cores from a different heat of material do not seem to have the same magnetic properties and, consequently, do not wortk as well. The valves need to open against 29 psi minimum pressure. The valves that have the issue will only open against 22-23 psi. The material certs would indicate that there are only mionor differences in chemistry of the heats of material. After some research I tested the hardness of parts from each lot. The good lot has a hardness of HB 122. The poorer performiong lot has a hardness of HB 142. Is this enough of a ahrdness difference to cause an issue withthe magnetic propertuies of the cores? I understand that 12L14 is not an optimum material for the application, but it has been in use in this application for 30 years and this issue has never been seen before. Does anyone have any suggestions on what could be happening here?
RE: Solenoid Core Magnetism
I would suspect that the solenoid has no force reserves and it is sensitive to tolerances, air gap changes and some mechanical friction. Without complete mechanical and magnetic analysis of the solenoid and external and internal loads, pressures and inertias it will be impossible to give an intelligent answer.
I would check the C.O.T of the 12L14 to make sure it is in the annealed condition, if it is not, that may be the reason for the higher hardness. If the core was supplied in the cold rolled or hot rolled condition instead of the annealed condition this may explain the change in the hardness and the decrease in magnetic properties.
http://w
Plymouth Tube
I would check the dimensions of the core added to the heat treatment. Maybe someting is not as the drawing specify.
Sreid
The magnetic alloys offered by Carpenter and far more expensive than 12L14 and much harder to machine. 12L14 is the best iron based low carbon alloys allow to machine. I assume the whole existance of the valve depends on the cheap price.
The machining cost of 1018 is more expensive than 12L14. 12L14 is especially designed as a super free cutting alloy for mass production on automatic machines.
More directly answering DennisP's question, the hardness of the material can reflect the internal stresses in the material and internal stresses can reduce the magnetic propertities of the steel as has already been said. Anneling the parts may fix the problem.
Critical components should be made from materials with controlled magnetic properties as mentioned before. Otherwise, this kind of problem will repeat randomly. The customer has to decide if it is cheaper to test & scrap complete assemblies or build in the quality at the design stage.
