Diverter valve question - Vendor or valve alternatives?
Who makes an inflatable seal tubular diverter valve for solids handling. So far I have only been able to find Zeppelin, a German Mfg co. Any USA companies a little closer?
As an alternative are there any multiport ball valves that might work? Cycling is only 1/month. T= 200 F max. Pr nomrally 6 psi 30 psi water used for cleaning. Cleaning washes out a solids buildup from dilute phase conveying.
Although the valve will not be actuated while water is under pressure, some salt water will get behind a ball and dry out. The concern is solids forming from evaporation, or powder that would work behind the ball, might seize it or score the seat/sealing surface when actuated the next time.
RE: Diverter valve question - Vendor or valve alternatives?
(From Memory, and it's been a while): They don't use a ball, it's a rotary cylinder.
As diverter valves for special applications are difficult to find on the market, you might come better out looking for a combination of single valves.
What about knife-gate valves?
So is this feasible with knifegates? I imagine it takes some sort of flush plate design and a special wye type fitting. The line is 4" round tubing 11 ga, although I could transition to square, if necessary.
I am currently making one for a major US oilfield co.
mohrfeld@premiumvalves.com
Mark Hutton
