Specifying an SAE port (J1926) - drawing callout
Hello all:
I did a search and did not find what I was wanted, I think this is a simple question: I am createing a drawing where a -8 threaded fitting will be installed and I need to specify to the machine shop what the machined hole will be. Is it as simple as a leader with "SAE J1926 -8"? I believe there is a tool the machine shop purchases to create these ports or at least rough it out and I would like to properly specify the port. Or do I need to specify all the machining details like here: (http://www.inserta.com/PDF/AI-STR-THD-PORT-DIM.pdf).
Thanks for the help.
Ron
Ron
RE: Specifying an SAE port (J1926) - drawing callout
Sorry .
John
Ron
Machines & Machining engineering Forum
