Autorun Macro
Autorun Macro
Autorun Macro
Is there a way to have a macro autorun whenever I open a certain part file?
Todd
RE: Autorun Macro
You can create an add-in for SolidWorks (kinda easy if you have the right VB installed), create a macro feature in the part itself (not easy), open the file from a macro (some what easy), or set up a macro to fun automatically when SW loads (not easy)
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
RE: Autorun Macro
Actually the running of a macro when starting SolidWorks is probably the easiest part. The Target of a SolidWorks shortcut just needs to be modified to include an -m switch and macro path;
"C:\Program Files\SolidWorks\SolidWorks\SLDWORKS.exe" -m "Full Path To Macro"
cheers
RE: Autorun Macro
Thanks Matt,
I will just run it from a shortcut key. One other question, please. Why do I get an error message whenever I try to run a macro ...test.swp has wrong format and cannot be converted to VBA macro file? I have never seen this before. Any suggestions?
Todd
RE: Autorun Macro
I haven't used it for a couple of years. I will experiment later.
Did you place the macro path in "" ?
cheers
RE: Autorun Macro
Matt,
The switch should have been "/m" (yes, in quotes).
As a test, place "C:\Program Files\SolidWorks\SolidWorks\SLDWORKS.exe" "/d" in the Target section of a SW shortcut.
Open a file or start new document and you should see a Developers Tools tab added to the main toolbar.
Not sure about the multi macro thing yet.
cheers
RE: Autorun Macro
You only need one macro.
CODE
Sub main()
Application.SldWorks.RunMacro("C:\StartupMacro1","Module1","main()")
Application.SldWorks.RunMacro("C:\StartupMacro2","Module1","main()")
Application.SldWorks.RunMacro("C:\StartupMacro3","Module1","main()")
'And on
'and on
'and on.....
End Sub
-handleman, CSWP (The new, easy test)
