How to use electrical routing ?
I have read the routing help ,and did following it .
But I have many problems , I want some help.
1.The default minimum bend radius check is always on,and I  can't close it. But in my computer, the space is not enough to put all wires with the right bend radius, I want to close the default check ,what should I do?
2.I route wires manually ,and for the computer's performance, I assemble many terminal blocks as a assembly,then I put this assembly into the final assembly .
But when I edit the wires ,appoint the from-to parts,if the  parts come from different assemblies, I can not do it .I just appoint the lines one by one. It's OK ,but after I saved it ,reopen,the wires properties disappear,the length of wire is zero.What happened? What's wrong ?
3.I drew some switch blocks ,with nomal open and nomal closed connecting points.Between the two points ,the line is  only one .But between the two Parts,there are two or three lines. I think the software don't remember the points , so I open the assembly again, the lines become  different,with the lines I closed it.One points starts with two wires .Another points thar should have one has nothing ,
it's orderless.It's not the same with it should be ,last time I rememberd.What should I do?
What wrong ?  If someone who have experience,could you tell me what to do ?  Thanks.
RE: How to use electrical routing ?
youngl9,
Did you get training from your VAR? Now that you have read the help manuals, you can call your VAR and they can easily answer your questions.
Bradley
SolidWorks Pro 2008 x64, SP3.0
PDMWorks Workgroup, SolidWorks BOM,
Dell XPS Intel(R) Pentium(R) D CPU
3.00 GHz, 5 GB RAM, Virtual memory 12577 MB,
nVidia Quadro FX 3400
Use SolidWorks BOM
e-mail is Lotus Notes
Did someone use it and it is successful ?
It is not easy to use and the help is not enough.
Is there some method to aviod ?
Is there someone who can answer me ?
Do not let me to call VBR.
I don't use SW Routing. But also don't understand most of your question. I suggest contact you VAR.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated 10-07-07)
