Design Journal Shown at Open
Anyone know if there is a way/setting to make SolidWorks open a document with the design journal showing? I would like it to be more utilized and made aware of, but even for me, I dont always think to use it. But Id like it to pop up right away so any important design info that is in there will be presented to any opening it. I know many will say to make it a disciplined part of our SW people, but to me that's not enough. Anything?
RE: Design Journal Shown at Open
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
You could also add a dummy feature to the part that is named "READ DESIGN JOURNAL." Again, no guarantees.
-handleman, CSWP (The new, easy test)
I can not find any access to Design Binder documents via API. I've tried. I wanted to write an addin that would alert user if the Design Binder had any content. No luck.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
I like the modified shortcut idea Handle, to make it as seamless and automatic as possible. But I have no idea how to do such a thing. Can you give any tips?
