Flexible Metal Hose
Flexible Metal Hose
I'm looking for an extremely flexible, 8" metal hose, stainless steel. I've tried the conventional convoluted metal hoses, but they just aren't flexible enough.
I believe there are some manufacturers that make the convoluted hose from layers instead of just a single ply of metal. Can't seem to find them on the net though.
Hose material must be non-magnetic, so 300 series stainless or possibly a copper alloy would be acceptable. Plastic (ie: Teflon) and rubber is not acceptable due to low temperature.
RE: Flexible Metal Hose
Good luck,
Latexman
Media Helium
Temp: Cryogenic
Thanks.
Or is it a cyclic loading you are looking for?
Layered convolutes will make the hose stiffer.
Normally metal convolute hoses are not that flexible, and have limited cycle life.
We have a braided corrugated metal hose that is meant for low pressures like you have, with a correspondingly lower STATIC bend radius of 10.5" for 8" diameter. Rated for 15psi at ambient temperature. ("Static" bend is for just a handful of bends, not constant bending, which is called "dynamic".)
The more standard of our metal hoses are for higher pressures.
www.flexicraft.com
