Beveled washer or not?
When must you use a beveled washer?  Is an angle spec'ed out that is allowable between bolt head and bottom of surface.  Please see attachment.
RE: Beveled washer or not?
what does a 40lbs piece of plate, 2'x10', have to do with a washer ?
AISC Steel Construction Manual 13th edition.  Page 16.2-40
6.1.1 When the outer face of the joint has a slope greater than 1:20...
The best way to test something is to squeeze it, slowly, until it breaks!
