Motor insulation testing - Polarization Index and loss-tangent testing
Could anyone explain the difference between Polarization Index and loss-tangent testing.
Since, both testings are checking the insulation of windings. Any pros and cons?
Thanks.
Thanks.
RE: Motor insulation testing - Polarization Index and loss-tangent testing
For Polarization Index see:
ht
for other see
http://
May be useful.
regards
tan delta or power factor uses more expensive equipment. Operation of the equipment can be a little more complex.
For motors, typically it would not be an either/or. You are always going to do IR / PI . If you want extra analysis / assurance, you also do a tan delta.
