Removal of parts during analysis
Hi everybody,
is it possible to "remove" a part during a simple 2D analysis using Abaqus/CAE? Accordingly to Analysis User's Manual, sec. 11.2.1, it can be made with the input
*MODEL CHANGE, TYPE=ELEMENT, REMOVE
but I'm using CAE. I'm trying to model the effects of a stepped excavation and need to take off portions of soil.
Thanks in advance.
Thanks in advance.
RE: Removal of parts during analysis
corus
Just 2 more questions: I opened the inp file created with CAE. But where do I have to insert the new line? And with this new file can I continue using CAE?
Thank you very much.
corus
I am having a similar problem. I too want to remove elementsbut want to do it to elements whos strain exceeds a set value.
Do you know how I can do this
Conor
again, thanks Corus for your help. As I said, I'm just learning Abaqus, so sometimes little tips make the difference between solving a problem or giving up. I now have my model working fine.
To Conor: sorry, I can't help in your problem.
Fdo.
That a very intresting question, If you find out the answer. pls post here as I am quite keen to know how to slove it. Wonder any subroute will do the job
Regards.
You can use cohesive elements for that purpose. There are well implemented in CAE since V6.6. Another way is to define a user element (UEL) with the wanted behaviour.
R.
Martin Stokes CEng MIMechE
