Container Yard Pavements
I have gotten involved in the design of a container unloading facility and I am looking for some references on pavements. The pavements will need to support lift trucks capable of reaching over one rail line and picking a 20-ton container.
I am assuming we will go with a slab-on-grade design but I would also like to see if a flexible pavement section would hold up to the loading conditions. I am working with the manufacturer of a potential equipment supplier to develop loading conditions, however, I am still looking for some references on designing the pavement section.
Any leads on references would be greatly appreciated. Thanks.
RE: Container Yard Pavements
For asphalt, you can probably use standard roadway design criteria, using loading and repetitions to come up with required structural strength.
Hope this helps,
Rob
They used a thickish HMA pavement, covered with a layer of sand, with precast pavers on top. Supposedly, the advantage is when the pavers get worn or cracked, you only have to replace that section and there are no cold joints or patches.
They have documents on design of concrete pavements for heavy industrial use (container yards, ports, warehouse parking lots, trucking facilities, etc.)
