Continuous Beam Thru Column
I have a situation where I need the column to not be interupted but I also need to make the beams framing into the web of the column behave like they are continuous. This is a elevated walkway with 14' cantilever on one end, 88' center span and 8' cantilever on the other end. The columns need to be continuous through the floor and roof to create a moment frame for lateral resistance of wind blowing perp to long axis of the walkway. The beams need to think they are continous to create the cantilvers on each end. I detailed stiffeners in the beam web to match the thickness of the flanges. These stiffeners were to be partial penetration welded to the column web and flanges. In turn the "simple span" beam and the "cantilever" beams flanges were to be full penetration welded to the stiffeners to transfer the tension and compression forces through the top and bottom. The contractor has requested instead of a full penetration weld that splice plates be used that are welded to the top flanges of the beams and to the web and flanges of the column. Will the deflection of the cantilever be adversly impacted by using the thinner splice plate versus welding the flanges to the stifferers. The flange/and stiffeners are 2" thick.
Thanks for the input in advance. This is a good web page to discuss these types of things.
RE: Continuous Beam Thru Column
to get the real deflection and bending, this needs to be analysed as a frame.
