hi-tigue
hi-tigue
hello, I'm from the Belgian Airforce, we fly hercules C-130H models. In my tech doc I can't find any torque-value's for the kfn542 nuts used to tighten the hi-tigues with diameter 3/16 and 1/4.
RE: hi-tigue
Based on my experience with Boeing/Douglas products, there should be something in Chapter 51 of the SRM that allows you to use nuts instead of the standard collar. Unless specifically shown otherwise, you would torque to standard specs for that pin/bolt diameter.
Hope that helps.
RE: hi-tigue
http://www.hi-shear.com/fastener_hlt_stds.htm
Hi-Tigue pins are designed to be installed with a certain collar that has a hex shaped drive element that shears off at a predetermined installation torque. The standard collar is finely engineered and duplicating that same installation torque/preload with a different nut will likely require some test work.
Of course, you could always try contacting Lockheed Martin. If the nut you specify is an acceptable substitution, they should have an established procedure for installing it.
RE: hi-tigue
RE: hi-tigue
RE: hi-tigue
RE: hi-tigue
