Relief Cut
Relief Cut
Relief Cut
Hello, everyone...
Where can I find litterature on relief cut? Does anyone know?
RE: Relief Cut
In relation to what? Shafting, threads, moulds or moulded products, engraving, sheet metal, flood control, origami, ???
cheers
RE: Relief Cut
Cheers, CorBlimeyLimey...
In this case we are talking notch relief groove related to tensile or compression in steel components, axisymmetric components, where the force acts in an axial direction.
RE: Relief Cut
Regarding cracking relief?
You may want to look at Peterson's Stress Consentration Factors.
Wes C.
No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced.
RE: Relief Cut
I don't have that book, but does it tell you how to get rid of the stress concentrations? I know where the problem lies, but not how to optimize my design...
--Tommy--
RE: Relief Cut
I use 1/32 inch on diameter, box X pin.  I then round to the nearest 1/64 inch fractional diameter.  Typically these are 1/4 inch wide, maybe 3/8 inch on the back of the box.
For example, 1.000 - 8 Stub Acme-2G  would exhibit a thread relief of 0.859 dia X 1/4 inch long on the Pin, and 1.062 inch X 1/4 inch long on the front of the Box (i.e. counter bore) and 1.062 inch X 3/8 inch at the back.
I like to break these reliefs with a 45 degree angle in all cases.
Note that you would apply the 1/32 inch over diameter relief to tyhe miniminm minor diameter on the Pin, maximum major diameter on the Box.  I have a threading program which determines this for me, good for Acme, Stub Acme and UN (coarse, fine, extra fine & special).  This saves me time in recomputing the proper threading geometry.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
