Corrosion resistance of 204Cu stainless steel?
Our current application is 3/16" diameter 304 stainless steel, cross wire welded to form a grate. The product is used in a veterinary environment. Would Carpenter Type 204-Cu (ASTM A313) provide similar corrosion resistance to animal products and general disinfectant cleaners?
grayseal
grayseal
RE: Corrosion resistance of 204Cu stainless steel?
Plymouth Tube
