Convert HPGL file so I can edit it in Catia V5 R17
I have a small number of HPGL files that I need to edit and save as a CATDrawing. Does anyone know of a free and effective way of converting these file in to a format that I can open ie DXF?
noevil
RE: Convert HPGL file so I can edit it in Catia V5 R17
Have you tried to open it with Catia?? Just checked "file open" and there is HPGL in the file type list.
Hi Azrael
Yes I have opened them in Catia but they can't be modified or saved as anything ells that can.
sadsadsad
i guess you have to get an empty drawing then do Tools / Import from file then get the GL2 file... (you might have to rename your file to match the type)
Eric N.
Thank you itsmyjob.
This works well enough to save it as a CATDrawing unfortunately it does not recognise the text as text but I can live with that thanks.
2thumbsup
KnowFear
