Hole depth tolerance
How i can mark hole depth tolerance in draft? Any idea?
RE: Hole depth tolerance
You can add a +/- as part of the hole call-out,
or if you require limits you may need to show a view with a dimension.
bc.
CAD2 Imagine Workstation
2.4GHz Core2 Quad
4GB RAM
Quadro FX4600
24" Iiyama widescreen
V
Actually it's not much like that but it's the best I can do.
You can then put +_ in the suffix with the appropriate valeu. Or you can put Min if appropriate. Or for limits as beach says you'd probably need to add a dimension in a section view or something.
If you mean you want to parametrically call up the hole depth then this is possible in several ways.
If you have a smart dimension on the hole, go to 'smart dimension prefix'. In the window that pops up you'll see over on the middle left a hole reference section. One of the options is hole depth. Simply select the suffix box, and click the relevant depth button. It will insert the required text to call up the hole depth.
Similar is available in callout, also in there you have the 'Smart Depth' and 'Hole Callout' tab to help you automate.
KENAT, probably the least qualified checker you'll ever meet...
