HAZ and PWHT
HAZ and PWHT
HAZ and PWHT
Where two are within min distance required for HAZ separation can PWHT get a the round the problem?
RE: HAZ and PWHT
There is no problem if the soak band for PWHT can envelope both HAZ's.
RE: HAZ and PWHT
In which standard is this 'HAZ separation' distance defined?
Steve Jones
http://www.pdo.co.om/pdoweb/
RE: HAZ and PWHT
No ASME standard defines the speration requirements by AS4041 says 4t.
RE: HAZ and PWHT
Does AS4041 then propose that PWHT is an acceptable alternative to maintaining the specified separation?
Steve Jones
