how to install EFD of catia
please, I need somedody says the rules to install the EFD of equipment and systems of catia in windows NT. the program tells me that it dont find the serv. and it is "nomada". thank you.
RE: how to install EFD of catia
The Steps to Run EFD are as follows:
Find your load of runOrbix.bat and runEFD
edit C:\DS\B08\intel_a\code\command\runOrbix.bat
echo off
rem############################################################################
rem COPYRIGHT DASSAULT SYSTEMES 2000 #
rem #
rem Component Class : Shell Script command to start orbix daemon #
rem #
rem Name : runOrbix #
rem Input : none #
rem Output : stdout #
rem #
set IT_CONFIG_PATH=C:\DS\B08\intel_a\startup\orbix
rem -----------------------------------------------------------------------
rem Start Orbix Daemon
rem ------------------------------------------------------------------------
"C:\DS\B08\intel_a\code\bin\orbixd" -u -s
pause
edit C:\DS\B08\intel_a\docs\runEFD.bat
@echo off
rem ################################################################
rem ### runEFD.bat: launch the electrical portal ###
rem ### ###
rem ### SYNTAX: runEFD.bat [portalpath][javapath] ###
rem ### portalpath: ###
rem ### Path of Portal runtime (ex: "c:\CATIA\BO7"). ###
rem ### javapath: ###
rem ### Path of Java Runtime (ex: "c:\jdk1.1.6"). ###
rem ### If the JDK has been installed in a path whose name ###
rem ### contains some spaces (example: c:\progam files\jdk), ###
rem ### then you need to specify the path between quotation ###
rem ### marks (example: "c:\program files\jdk"). ###
rem ### ###
rem ### Copyright DASSAUL-SYSTEMES 2001 ###
rem #################################################################
set CLASSPATH_OLD=%CLASSPATH%
set PATH_OLD=%PATH%
rem ### Location of JRE (or JDK)
set javahome=c:\jdk1.1.8
:EndJRE
rem ### Defines location of JARs for Portal's native
set PORTALPATH="C:\DS\B08\intel_a\docs\java"
:EndRuntime
rem ### Defines CLASSPATH
set CLASSPATH=%javahome%\lib\classes.zip;%javahome%\lib
set CLASSPATH=%CLASSPATH%;%PORTALPATH%\GW0Start.jar
set CLASSPATH=%CLASSPATH%;%PORTALPATH%\PLNallnative.jar
set CLASSPATH=%CLASSPATH%;%PORTALPATH%;%PORTALPATH%\..\..\code\command
echo Electrical Portal is starting...
echo ---------------------------------------------------
echo Java runtime path=%javahome%
rem echo CLASSPATH=%CLASSPATH%
echo Portal runtime path=%PORTALPATH%
set path=%path%;%PORTALPATH%\..\..\code\bin
%javahome%\bin\java -ms16m -mx128m -classpath %CLASSPATH% -Ddebug=false -DFilePrefix=Elec com.dassault_systemes.catweb.frame.applet.SwingJARStarter %PORTALPATH%
:EndScript
set CLASSPATH=%CLASSPATH_OLD%
set PATH=%PATH_OLD%
ΓΏ
Start runOrbix.bat
Start runEFD.bat
Log-in with user id on workstation
Select Electrical Design Icon from CATIA Portal.
EFD IS RUNNING!
I hope this helps.
Timothy J. Suhr
