valve class vs max.pressure
your prevous input helped me quite a bit.
I have a question that is probably lame but can't seem to find an answer on the web.
I need a reference table comparing valve press. class vs. max. allowable pressure valve can handle.
Would any of you have this information, it would be greatly appreciated.
RE: valve class vs max.pressure
The metals are based upon ASTM/ASME materials. You can also cross reference using UNS numbers. As multiple tables exist for carbon steel I avoid the simplified vendor catalog data. Anything more exotic than carbon steel has lower pressure rating than the steel tables at the same temperature.
http
h
http://virtualpipeline.spaces.msn.com
"What gets us into trouble is not what we don't know, its what we know for sure" - Mark Twain
