Future of engine ECUs & control strategies
I'm looking for opinions.
I mentioned in another thread that I think future engine control strategies are likely to be based on cycle-by-cycle individual in-cylinder conditions (measured or predicted).
This will require cheap and robust sensors, and/or sophisticated hardware/software.
Any thoughts or comments?
- Steve
RE: Future of engine ECUs & control strategies
I know one argument for plastic manifolds was that they could have more consistent cylinder to cylinder air flow and therefore reduce the need for individual cylinder fuel trim.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
What was surprising, then, was the amount of useful cycle by cycle information that could be gleaned from a single sensor.
I'm pretty sure the patents have run out.
I'd be very surprised if current ECUs >didn't< have a little code in them based on the core technology... which amounted to diddling something at random just a tiny bit, measuring the engine's response over the next few cycles, and biasing the controller's setpoint in whatever direction produced an improvement.
Mike Halloran
Pembroke Pines, FL, USA
However as an example of how difficult it is to analyse performance from that data look at this amateurish webpage
ht
I don't see why a high pressure pressure transducer in mass production necessarily has to be expensive, so true in-cylinder measurement may be feasible. However they are a bit tricky to package.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
One problem with any cycle-by-cycle analysis of an IC engine (especially gasoline) is the combustion process itself, which is inherently chaotic and has very high variability. This variability is such that some form of averaging must be performed in order that a statistical meaningful value can be calculated, even during steady state running. Since most IC engines spend their time operating transiently the signal to noise ratio of the in cylinder measurements is going to be far too high to be useful.
I have also heard the notion of 'adaptive spark advance' (not knock control) whereby the spark is advanced until just on the borderline of knock (often, but not always, the most efficient setting). This sounds good but since there is no torque feedback it cannot be guaranteed that this is the most efficient setting. In addition to that the fact is NOx emissions are always going to be affected would make a compliant emissions calibration impossible to achieve.
Having said that, there do already exist systems, such as adaptive knock control & misfire detection, which operate on a cylinder specific level. These use knock sensors & the acceleration of the flywheel, respectively, with good results. Some EMS systems also have an idle speed stabilisation control but, once again, crank accelerations are also perfectly adequate for this. I suppose that in cylinder monitoring could be used in these functions, within a feedback system, but I am sceptical that there is a requirement. After all, surely, in using in cylinder measurements you are just swapping one feedback signal (i.e. crank accels.) for another (i.e. in cylinder pressure) with no gain?
In terms of emissions control, the main factor is the cold start, not individual cylinder conditions. Once catalyst light off has been achieved tail pipe emissions can be reduced to almost negligible levels. It is the period before light off in which most emissions tests are passed or failed. Especially when there is a prolonged period of open loop fuel control and high feed gas emissions.
After light off the next major emissions contributor tends to be transient fuelling control and catalyst O2 clearing. Both of which are greatly aided by GDI technologies, which greatly reduced catalyst breakthrough when properly calibrated.
I can't see how any of the above would be greatly helped by in cylinder measurements.
MS
The spirit of much of what you are saying is true today, but it will not be true in just a few years. For example, "Once catalyst light off has been achieved tail pipe emissions can be reduced to almost negligible levels" is roughly true today - although probably only for SI engines - but it will not be true by the 2012 emissions cycle when the targets are so low that a bit of off-nominal operation in a cylinder for just a few minutes can cause an emissions failure regardless of the catalyst performance.
Also - when you say "After all, surely, in using in cylinder measurements you are just swapping one feedback signal (i.e. crank accels.) for another (i.e. in cylinder pressure) with no gain?" I'm with you until those last three words. There are things you cannot detect with the crankshaft - temperature & composition being two big ones - that can at least in theory be detected in-cylinder or near-cylinder. Further, finding things out from the crankshaft is more complicated (algorithmically, not environmentally of course) than an in-cylinder detection. You have multiple cylinder events occurring on a flexible crankshaft with harmonics bouncing through it, and further a transmission and a flywheel tugging on it. We can sort through all that to detect complete misfires, but any better resolution than that is suspect.
On engines that propose to use some variation of HCCI during some portion of the speed/load regime (for emissions reasons), this type of feedback will probably be necessary to fine-tune injection timing for reliable ignition at the right time.
We haven't even disscussed high resolution crankshaft sensor's and faster PCM's which first need to sample the crankshaft waveform for a reference, and then once learned, can use small variances to that waveform in order to sense engine missfires. This system even provides feedback to be sure that variable displacement has occured correctly, and works with variable engine mount dampening, and active noise cancellation so that the driver doesn't notice the change in the way the engnie is running.
While pressure transduecers would be an interesting addition, you have the problem that by increasing the number of parts, you increase the potential number of failures. Plus you also have to deal with the added weight that has to be hauled around for the lifetime of the vehicle.
Caterpillar ADEM III control system provides electronic governing integrated with air/fuel ratio control and individual cylinder ignition timing control.
Custom control system software is available for non-standard ratings. Software is field programmable using flash memory.
- Steve
Instead of sensors acting in a phenomenologically-based feedback loop and a relatively "dumb" look-up method, future systems will have physics-based models that basically stores equations of physical processes instead of mapped values.
The objective here is to minimize the number of sensors, because each added component increases cost and the size of the BOM, as well as represent potential failure modes. Another reason is that, as explained above, they're rather dumb: sensors work on historical sensed information and don't do well to look-ahead and compensate for engine wear, variations, and sensor deviations/deterioration.
An example might be emissions control, which is key to the move toward model-based control because of regulations that require emission control systems to be functional and still meet stringent tailpipe limits to 120,000 miles. With a sensor-based system, the O2 sensor is critical to knowing the composition of the exhaust gas. Model-based control may not eliminate the O2 sensor in this case, but the ECU will have physics-based models that can basically calculate almost everything the ECU would need to know based on a more limited set of sensed inputs.
Some of the prechambered gas fueled engines are using combustion feedback, it looks at the amount of time the flame front travels across the cyliner starting the time from when the primary igniton pulse fires the coil.
Yes, lot's of cost and hardware, but in this size range a couple of points in effciency of a few ppm of NOx is a big deal for an engine running over 8000 hours a year.
We have also seen test injectors with on board pressure transducers, something some of the factory engineers indicate we may see as a part of high performance packages full time.
It has been a pretty interesting last few years with technology improvemetns on the larger engines, and expect with desire for lower emissions and fuel consumption, that the complexity and capability of engine controls in our market will continue to advance. And we see in our market that technology that was on the larger engines a few years ago is now moving to the smaller size units.
The challenges from a field perspective? Making the service tooling as smart as the engine controls. Having reasonable service life for the sensors being installed, and having the design engineers listen to the field folks when they report problems and come up with real world diagnostic procedures and solutions.
Just my two cents.
