ASME Section VIII vs ASME Section IX
Can anyone give summary of differences between ASME Section VIII and Section IX?
I see that Section IX claims to be an international code, but how does it differ from Section VIII?
Can a Vessel design and built to Section VIII be accepted by Section IX?
Thank you for your anwers.
spxapps
spxapps
RE: ASME Section VIII vs ASME Section IX
Section IX is welding qualification.
When you build pressure vessel per Section VIII by welding, you are using Section IX for welding qualification.
genb
Steve Jones
http://www.pdo.co.om/pdoweb/
There are many Countries now accepting ASME as their standard, are more than the ones which do not accep it.
If you want to make it more Int'l, go further with ASME-ISO
Int'l...
genb
