ASCE 7-05 load combinations
Formula 12.14-6 defines D as "effect of dead load". Does anybody know if that is the same D as in 12.14.3.1.3 combination #8 ? Isn't D the Dead Load ? what is the "effect of dead load"?
RE: ASCE 7-05 load combinations
In other words, you apply the loads on the structure in the various directions that they occur (lateral, vertical) and the effects are the axial, shear and moments that result.
Thus, the combinations are really combinations of effects, not loads. But to analyze it you apply loads to the structure.
Here are links to two previous threads discussing the use of "D" in a seismic combination:
thread176-98527: ASCE 7-02 Seismic Load effects
thread487-121459: Seismic Load Effect E (IBC 2003)
