Piping Elbow Design
Piping Elbow Design
Piping Elbow Design
Im new to Compress and am using it on an exploritory basis.  I want to have an outlet nozzle exiting the bottom head of a vessel and I want it to bend 90 degrees and exit the vessel skirt.  Any suggestions?
RE: Piping Elbow Design
At this time COMPRESS does not provide any feature to attach components to the end of nozzles other than flanges, bolted covers, welded covers, or heads. There is no option to attach elbows and extended piping beyond the end of the nozzle.
"Although this forum is monitored by Codeware it is not intended as a venue for technical support and should not be used as the primary means of technical support."
  Tom Barsh
  Codeware Technical Support
