TJI End Reaction
TJI End Reaction
I am trying to determine the design assumptions which limit the end reactions on a TJI joist.
The confusion for me lies when comparing intermediate allowable reactions and end reactions.
TIA
TIA
RE: TJI End Reaction
Would you happen to know the design check for this?
Out of curiousity, I just ran a continuous joist with point load near the end (using TJ-Beam). As end bearing the joist failed in end reaction. I then assumed 2x4 support wall and cantilevered the joist 2" over and the joist worked fine.
This little experiment in this case is going to save $8,000 on my project.
The notes for end reaction made much more sense to me. The note saying for 4" Bearing or greater set the end reaction to max. shear.
I have another reason for this post. I am sure others have encountered what I have regarding floor systems being redesigned by lumber suppliers. In a nutshell I have had numerous times where our design would be scrutinized and redesigned by the supplier. This last time was a set of shop drawings with TJI doubled in lieu of singles. The response from the supplier was our design was flawed and their program told them doubles were required. I requested the calcs and reviewed.
1) End bearing input was 3" with a rimboard (1.88" Effective). Joists bear on 2X8 plate.
2) Higher loads then required.
Using their loads and the cantilever approach I mentioned the joists work within their software. Using the intended loads the joists work either way.
I feel this is a problem in our industry regarding the suppliers of trusses, joists, etc. designing buildings using software they do not understand and with limited engineering knowledge.
http://www.i-joist.org/pdf/Asd_ij.pdf
