Min Distance Between 2 Circle Diameters
Using solid works drafting how would I use the smart dimension icon to put a dimension on that would show
a minimum distance between 2 circles?
Thanks in advance.
Thanks in advance.
RE: Min Distance Between 2 Circle Diameters
1.) Dimension the distance between the two circles by clicking the OD of each circle. It will dimension centerline to centerline
2.) left click the dimension you created, and the properties window will open on the left side of the screen (where the history tree is)
3.) Click the tab marked "leaders" at the top of the properties window
4.) in the "arc condition" sub window, click both "min" option buttons.
This will give you the min distance you are looking for.
Hope this helps.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
