Custom Properties / Callouts
Hey guys,
If I create a customer property, in this instance called 'SITE' and fill it using info from the propseed file, I'd like to fill it with something that looks like this:
'ABC blahblahblah'
Then on the drawing border I'd like to have a callout which gives the 'SITE' variable, but only the first three characters. Is this possible and if so, how?
Many thanks in advance,
Simon
'ABC blahblahblah'
Simon
RE: Custom Properties / Callouts
KENAT, probably the least qualified checker you'll ever meet...
You are using property text which is placed using the Call-Out command and the text does not have a 'box' around it.
bc.
CAD2 Imagine Workstation
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
